  3. asiSelectNet doesn't work!
  • Views 1207
imagesensor123
imagesensor123 over 13 years ago
Hi all,
    have you seen this script in the artist skill user guide, i find it doesn't work in my case. by the way, i use ic5141 and ams370.
this error info:
 Message: *Error* No method supplied for generic function asiGetSimName
 hiCreateStringField(
    ?name ’net1
    ?prompt "Net Name"
    ?value ""
hiCreateButton(
    ?name ’netSelect1
    ?buttonText "Select"
    ?callback "asiSelectNet(’net1 ?prompt \"Select net1\")"
what's the problem, tell me please!
    Usually forms which use asiSelectNet will have been created as part of an ADE integration, and so will use the appropriate functions to set up the form appropriately.
    However, for a form, abVDCform in the example below, you can add a property on the form to tell it the asi session:
         abVDCform->asiSession=asiGetCurrentSession()
    or however you're getting the session (maybe sevEnvironment(sevSession) - do whatever works for your customization).
  • imagesensor123
       sorry, i can't understand your solution very well. "abVDCform->asiSession=asiGetCurrentSession() " , what do you mean by the "abVDCform", is it a common form created by the function"hiCreateAppForm()", how to add the asiSession property to a given form? if this is ok, and then how to use the asiSelectNet(), it will work like the example showing in the user guide. i am a new guy about the ADE customization. thanks for your explaination.
    My example is not quite as you'd want it - but here it is:
    procedure(abPlotVDC()
        unless(boundp('abVDCform)
        hiCreateAppForm(
            ?name 'abVDCform
            ?fields
            list(
                list(
                    ?name 'net
                    ?value ""
                    ?prompt "Net"
                0:0 400:30 100
            ?callback 'abPlotVDCCB
        asiSelectNet('net ?form abVDCform)
    In my case, I don't actually want the form to appear - so I'm creating the form to keep everything happy - but the idea is that whatever variable you are using to store your form in needs a property called asiSession storing the asi session id. When asiSelectNet is called, it will either use the specified form, or the current form (I think) to identify the "asiSession".
    So you need to add a property called asiSession to your form.
    I'm a bit rushed to put together a more complete example. There's one in solution 11256686 though.
  • imagesensor123
        yes, i think that the asiSelectNet function needs a form which contains the "asiSession" information,  so that it can know where to find object(associated objects), here, it's a net, as you said, this function is properly added in the ADE, so there should be a property storing the asiSession, i got it. thanks
