  3. how to dispply the simulation output file(output log file...
  • Views 4356
how to dispply the simulation output file(output log file) in a standalone window?
imagesensor123
imagesensor123 over 13 years ago
Hi all,
    in cadence ADE, I create a form and I start the simulation by clicking the button in the form, but i found all the output log will display in the CIW window, it's a  problem for me, because i am doing a long simulation , i mean i have to run the simulation many times ,so i can't use the CIW any more, I think it's better to display the simulation in another window, just as the "parametric analysis tool" does, in that case, we can also use the CIW while the parametric simulation is going.  i did not find any function tell about this, do you have some idea?
    Given that you've not explained how you are running the simulation - i.e. what the button on the form does - advising you is difficult, unless one of us writes your entire application for you (which would be rather time consuming). You've given very little information to go on (no version information either).
