  3. How to know the codes behind layoutXL and layout turbo.
  • Subscribers 148
  • Views 13961
Sarvani
Sarvani over 13 years ago
 hi all,
        1)I want to know the codes running while layout XL routing.  Probing the nets in schematic and layout when we routing the that same net in layout. No need of exact code, similar code is enough for me. Is there any codes?
        2) Is there any script which is doing job like as DRD option in layoutXL.
     Thankyou
    Why do you need this?
  • Sarvani
                   Now I am practicing on skill languge by writing little codes by viewing Documents's in COS,  in my install directory , and in forum. I thought if I know that code for probe in XL then I can generate some extra features then that. I need just consept behind that feature.
    Probing nets can be done using geAddNetProbe() or with one of the geMakeProbeWithColor type functions.Start cdsFinder from the UNIX command line and look for ge.*Probe - and then search for the function you want in cdnshelp (if using IC61X) or cdsdoc (if using IC5141).
    DRD is quite a complex piece of software, so you're not going to be able to write that with a few lines of SKILL code! Hardly a good place to start learning how to write SKILL. I wouldn't be able to give you the code, or even the algorithm outlines as it is proprietary, and anyway it would be way too long and complex...
