  3. How to display the output of a program in a seperate form...
  • Views 14432
How to display the output of a program in a seperate form?
mvijay
mvijay over 13 years ago
I have a small code which finds the coordinates of instances of interest. I intend to put the coordinates obtained from the code in a seperate form for ease of display. It is on the same lines as we see the design hierarchy output form. Look forward to know the function to get the same.
Kind Regards
Vijay
  • ghost
    ghost over 13 years ago
    Hi Vijay,
    If you are intending just to display the result, there are two options
     1. use outfile() to write to a file and view.
     2. use Dialog boxes to display the result, ex; hiDisplayAppDBox()
    Regards
    Ajay
  • Sarvani
    Sarvani over 13 years ago
    I have some code which is works as you want. First you need to save this in file and load it. And then enter TrShapeReport(cv) in CIW. Hilighted code is for printing output at form(you can write here for your output).
     cv = geGetEditCellView(  )
    procedure( TrShapeReportToPort( cv outport )
    let( ( rectCount polygonCount pathCount miscCount )
    rectCount = polygonCount = pathCount = miscCount = 0
    fprintf(
    outport
    "%s %s %s contains:"
    cv~>libName cv~>cellName cv~>viewName
    ;if u write anything in printf(outport............) format then that will be printed in on output file
    foreach( shape cv~>shapes
    case( shape~>objType
    ( "rect" rectCount++ )
    ( "polygon" polygonCount++ )
    ( "path" pathCount++ )
    ( t miscCount++ )
    ) ; case
    ) ; foreach
    fprintf( outport "\n%-10s %-10d" "Rectangles" rectCount )
    fprintf( outport "\n%-10s %-10d" "Polygons" polygonCount )
    fprintf( outport "\n%-10s %-10d" "Paths" pathCount )
    fprintf( outport "\n%-10s %-10d" "Misc" miscCount )
    list( cv~>libName cv~>cellName cv~>viewName )
    ) ; let
    ) ; procedure
    ;below procedure is used for showing the form
    TrReportBBox = ’((120 729) (372 876))
    procedure( TrShapeReport( cv )
    thePort = outfile( "/tmp/ShapeReport.txt" )
    when( thePort
    TrShapeReportToPort( cv thePort )
    close( thePort )
    ) ; when
    view( "/tmp/ShapeReport.txt" TrReportBBox "Shape Report" )
    ) ; procedure
    I hope this will help you.
    Thank you
  • mvijay
     Thanks a lot Ajay,Sarvan.
