  3. How to print unicode characters in SKILL?
  • Views 15833
berndf
berndf over 13 years ago
Is it possible?
If yes, how?
 Bernd
  • skillUser
    skillUser over 13 years ago
    Hi Bernd,
    My guess is "no" - you can specify characters by an ASCII value between 0-255, and if I understand correctly, the scope of Unicode characters is much bigger than this. In SKILL you can give a character by a backslash followed by a three digit octal number, but you are limited to the range I mentioned I believe.
    Lawrence.
  • tweeksold
    tweeksold over 13 years ago
    SKILL strings can store the bytes making up Unicode characters, but the CIW does not know how to interpret them for display.  E.g.,
    printf("\342\210\236")
    This is the UTF-8 encoding of an infinity symbol, but if you try that in the CIW, you'll see some other character depending on your font, e.g. an "a" with a circumflex.
    Nevertheless, you can still write the character to a file and display it in another application.  E.g.,
    fp = outfile("~/unicode_test.txt")
    port:"~/unicode_test.txt"
    fprintf(fp "\342\210\236\n")
    t
    close(fp)
    View the file in an application that understands Unicode (e.g. Emacs) with a font that has a glyph for the infinity symbol, and you'll see it.
  • berndf
     Thanks guys.
