  3. How can I search a selected netname?
  • Subscribers 150
  • Views 19356
David Qiang
David Qiang over 13 years ago
Hello
How can I  get the netname of my selected wire and search this netname by bindkey. I have try "dbGet selected.name" , but fail. Maybe I had used it by a wrong way? pls give me a reference code.
Thanks in advance.
  • skillUser
    skillUser over 13 years ago
     Hi David,
    this does not look like a SKILL query to me, which tool are you trying to do this in, and which version?
    Lawrence.
  • David Qiang
    Hi
    I want to do it in Cadence's Schematic editor view, Cadence's version is 5.10.41_USR6.127.29 .
    David
    How about Edit->Search->Find and then change what you're searching for to be "netName"?
  • markbeck
    markbeck over 13 years ago
    I don't know if this is what you had in mind, but I read your request as you wanting to highlight all figures associated with a selected net.
    One possible solution would be to:
    1. First, get the wire object: d_obj = (caar (geGetObjectSelectedSet))
    2. Then, query the object's net: d_net = d_obj->net
    3. Then,query the net's figures:  l_figs = d_net->figs
    4. Finally, you can highlight all of the figures associated with that net with: (geSelectFigs l_figs)
     Mark
