  3. runObjFile for ocean corner simulations family plots?
  • Views 13823
yayla
yayla over 13 years ago
I am running corner simulations using ocean script and saving results at different folders like ss_50, ss_125 ... I want to plot these results together using Spectre Waveform tools. For this purpose, I have run a parametric simulations from GUI and if I am correct, Spectre uses runObjFile under top level psf for family of plots since by modifying it, I can plot the corners I wanted. My question is that how can I modify an existing runObjFile for my oceanscript so that I can see the results like in GUI? I tried to modify but in CIW, I see the error messages saying that "Warning Data in xxx.directory doesn't correspond to the cellView in Window Aborted" and I cannot plot the results.
I saw a thread in 2010 at www.cadence.com/.../61892.aspx. Is there an update/solution to this issue?
 yayla
    Yayla,
    As I said in the previous thread, there's no public function (only private ones) for this - you should contact customer support to request an enhancement to provide a public function.
    Using any of the Cadence ways of performing corner simulations (e.g. OCEAN XL in IC61) will produce the runObjFile for you.
