  3. hierarchial summary
  • Views 14594
hierarchial summary
deep242003
deep242003 over 13 years ago
I want to derive hirerchial summary of a layout(instance names and mosaics. dbGetTrueOverlaps() gives the data in form of layers(please correct if I am missing anything).
while dbProduceOverlapIns() has no hierarchial option .
Any suggestion or hint willl be of great help.
    Are you trying to find the instances in a particular region of the layout, or in the complete layout? It just seemed a slightly odd requirement to find all the hierarchical instances in just a portion of the layout, so thought I'd better ask you to clarify.
  • deep242003
    i need for the whole layout.. even if i can make for small area,i can use ~>bBox to aply for whole layout. i m looking sth similar to lehisummary() but needs hierarchial dta rather than only current layout.
    Using a region query is kind of overkill in that case. You could just write a recursive function to do this - there have been many examples of similar things on this forum before. Since you want instance information, something like:
    procedure(MyUntestedLayoutInfo(@optional (cv geGetEditCellView()) (depth 0))
      let((format)
        foreach(inst cv~>instances
          sprintf(format "%%%ds%%s %%s\n" depth)
          printf(format "" inst~>name inst~>cellName)
          MyUntestedLayoutInfo(inst~>master depth+1)
        t
    Needs a bit of work to handle mosaics (and as the function name suggests, I wrote this off the top of my head and didn't test it)
    Hope that helps,
  • nonyann
    nonyann over 13 years ago
    Hello Andrew,
     I'm curious, how to save the hierarchical summary file into certain directory?
    Nony
    You'd need to use fprintf() instead of printf() in the code, and pass in an open file handle (as produced by outfile()).
