  3. How to view a file which is named QQ[0].txt ?
  • Views 864
Charley Chen
Charley Chen over 13 years ago
Hello ,
In unix , I have a file QQ[0].txt , when I use command  vi  QQ[0].txt  it will becomes  vi  QQ\[0].txt , it can be opened.
So it needs a back slash before \[  .
When I use isFile("QQ\\[0].txt") ==> nil ,
What's the way to determine a file which has bracket is exist ?
Thank you,
Charley
    Charley,
    You would just use isFile("QQ[0].txt") . No need to escape anything. The only reason you're having to escape the [ in the shell is because [ is a special character for the shell...
    getDirFiles("containingDir")
    will show you the actual names of the files.
  • Charley Chen
    Andrew ,
    It works.
    Thank you,
    Charley
