  3. Skill code for turn rectangle metal to mesh in the virtuoso...
  • Replies 8
  • Subscribers 150
  • Views 18777
Skill code for turn rectangle metal to mesh in the virtuoso layout editor
ZhouDL
ZhouDL over 13 years ago
I want write a skill script for turning rectangle metal to mesh or slot on the rectangle metal automatically in the virtuoso layout editor when I press a bindkey.
but I am not very familiar with cadence skill .Can anyone help me on this?
PS: I want to post some sort of screenshot from my computer for what I really want to do,but I do not know how to do.Anyone can teach me to do this?
  • skillUser
    skillUser over 13 years ago
    If you reply to the message thread in a browser you should see tabs across the top ("Compose", "Options"... ) - select Options and you should be able to upload a jpg/png image of what you are wanting to do.  A picture is worth a thousand words, so this would help I think.
    Without seeing the desired result I would guess at using chop rectangles within the original rectangle to obtain a complex polygon with holes in it. Or perhaps replace it with horizontal and vertical overlapping strips and then merge into a single shape?  There might be multiple ways of doing this...
    Best regards,
    Lawrence.
    If using IC615, you can either create metal slotting during creation of shapes (such as rectangles), or using Edit->Advanced->Slot.
    So maybe that does what you want as a standard feature.
  • ZhouDL
    Best regards,
    Lawrence.
    thanks for your suggest. But I do not know how to write skill language to implement this, can you help me this in detail?
    I have posted some sort of screenshot as follow.I want to turn solid rectangle metal (left screenshot) to mesh (right screenshot) when I press the bindkey.
  • ZhouDL
    Best regards,
    Lawrence.
    I have posted some sort of screenshot as follow.I want to turn solid rectangle metal (upper screenshot) to mesh (down screenshot) when I press the bindkey.
  • ZhouDL
    Thanks a lot.But I use IC5141,so I have to write skill script.
  • dmay
    dmay over 13 years ago
    Try this code. It will create a polygon instead of strips of metal.
    procedure(meshSelected(@key (meshWidth 1.0) (cv geGetEditCellView()))
      let((shape box innerBox rects mesh)
        shape = car(selectedSet())
        box = shape~>bBox
        innerBox = list(xCoord(lowerLeft(box))+meshWidth:yCoord(lowerLeft(box))+meshWidth
                        xCoord(upperRight(box))-meshWidth:yCoord(upperRight(box))-meshWidth)
        rects = rodFillBBoxWithRects(
            ?cvId geGetEditCellView()
            ?layer "y0"
            ?fillBBox innerBox
            ?width meshWidth
            ?length meshWidth
            ?spaceX meshWidth
            ?spaceY meshWidth
            ?gap 'minimum ;optionally 'distribute
        mesh = dbLayerAndNot(cv shape~>lpp list(shape) rects 1000) ;last # is max # of vertices
        dbDeleteObject(shape)
        mapcar('dbDeleteObject rects)
        mesh
      ) ;let
    ) ;proc
    Select your piece of metal and run this command, filling in the appropriate number for the width of your holes. I coded a default of 1.0. Also, the program above keeps the holes at a minimum space (meshWidth). If your rectangle is not a perfect multiple of the meshWidth, you'll end up with wide strips at the top and right. You can change the ?gap argument to be 'distribute and the mesh will be more even.
    meshSelected(?meshWidth 2.0)
    Derek
  • ZhouDL
        box = shape~>bBox
            ?layer "y0"
            ?fillBBox innerBox
            ?width meshWidth
            ?length meshWidth
            ?spaceX meshWidth
            ?spaceY meshWidth
        mesh
      ) ;let
    ) ;proc
    Derek
    Thanks a lot,Derek.I will try it.
  • cadengr
    cadengr over 12 years ago
     It works for me. Thanks for posting it.
