  3. How do you create a simple Neural Network in Skill
  • Subscribers 150
  • Views 14398
Adhil
Adhil over 13 years ago
Hey!
I have been thinking of a few useful programs that could benefit from neural network, can anyone help me create  a simple one which i can enhance or play around with? :)
Adhil
  • Quek
    Quek over 13 years ago
    Hi Adhil
    I think perhaps you can try googling "lisp neural networks" for more answers. Lisp is the parent of SKILL. Here are some useful books:
    http://aima.cs.berkeley.edu/
    http://www.amazon.com/Common-LISP-Modules-Artificial-Intelligence/dp/0387976140
    Best regards
    Quek
  • Adhil
    Hey Quek
    Yep i was trying it out before i posted, however, the lisp format is so bracketty- people get confused. i was shooting for a skill code(which im used to) to launch an exploration.
    Thanks anyway for the tip
    Adhil.
  • skillUser
    skillUser over 13 years ago
    Hi Adhil,
    SKILL is based on LISP, so it has the same 'confusing' parentheses, however, you may be referring to the code style - typically you may see the "C-style" syntax used as opposed to the LISP style. When you read code in to Virtuoso, if you then pretty print ('pp') the function out you will most likely see it represented in the C-style format, even if it was originally written in the LISP style format.  This is controlled by the printinfix internal switch:
    ;; check the syntax style switch setting, default is "t"
    status(printinfix)
    => t
    ;; change the syntax style to the LISP style syntax
    sstatus(printinfix nil)
    => nil
    So you might load some examples and then 'pp' the functions (to a file even) for further reading, in the C-style.  Of course, some of the examples might be written in a LISP 'dialect' that SKILL does not understand, so you may have some rewriting to do!
    I hope this helps!
    Lawrence.
