  3. Help converting skill from IC5 to IC6
  • Views 15553
blankman
blankman over 13 years ago
Hi All,
I have some skill code below im hoping to convert from IC5 to IC6. I know many functions/commands have changed with the switchover, however I haven't had much luck myself trying to convert.
I am also seeing that the keypad keys are non functional or semi functional in IC6. Would there be a workaround for this?
Any help much appreciated, thanks!
;Changing via type
procedure(BSchangetoVia1()
let((newMaster)
        foreach(fig geGetSelSet()
                when(fig~>objType=="inst"
                        newMaster=dbOpenCellViewByType(fig~>libName "met2_met1_b" fig~>viewName)
                        fig~>master=newMaster
                        dbClose(newMaster)
                        printf("Contact type = %L\n" fig~>cellName)
                );when
        );foreach
);let
);procedure
hiSetBindKey("Layout" "Alt<key>KP_End" "BSchangetoVia1()")
;Changing via columns
procedure(BSchangeViaVertDecPathFine()
let((message x1 x2 dx labelheight point win hs Right Left Top Bottom dx1000 intdx1000 a RightNew LeftNew LowerLeft UpperRight newbBox sum crdList firstPt lastPt areap)
                        prop=dbFindProp(fig "column")
                        if( prop != nil
                                then    if( fig~>column >= 3
                                                then fig~>column = fig~>column - 1
                                                else dbDeletePropByName(fig "column")
                                else    nil
                        );if
                        printf("Colums = %L\n" fig~>column)
                );when
        );foreach
);let
);procedure
hiSetBindKey("Layout" "Shift Alt<key>KP_Subtract" "BSchangeViaVertDecPathFine()")
    Quick answer as I'm a bit short of time.
    You might find this post useful . To find existing properties on a via, you will need to look at fig~>viaHeader~>overrideParams. Note that fig~>objType will be (say) "stdVia" not "inst" any more. So to get the columns it would be cadr(assoc("cutColumns" fig~>viaHeader~>overrideParams))
    To replace the via, you'll need to do a dbCreateVia again.
  • blankman
    Thanks Andrew, ill give it a go. Would you've an idea why the IC6 keypad keys are only semi functional? Are they in use for another function?
    Rgds,
    Brian.
    Brian,
    The bindkeys you list work for me - I can see the functions being called (even if they don't work because of the code).
    In some cases you probably need to bind the key as Alt<Key>KP_1 rather than ShiftAlt<Key>KP_End (for example). It also will depend on whether Num Lock is pressed or not, I guess.
    If you use the new BindKey editor, you can press the key sequence when you're editing the bindkey - and it will then tell you the magic sequence describing the key.
    Note that in general Alt bindkeys don't work (this is more for the letters on the keyboard) because the Alt key is used for menu accellerators (that can be controlled though using a cdsenv setting - see solution 11315096  )
  • blankman
    Thanks Andrew,
    Yes KP_1 seemed to do the trick. Though Im now seeing some unexpected behavior with the shift key. I'll have a chat with my CAD team here and see if its something on my end thats causing it.
    Brian.
