  3. SKILL expression for CDF display property
  • Views 15441
Yaosan Yeo
Yaosan Yeo over 13 years ago
I'm trying to create a function to set whether one of the CDF parameter should show up based on the value of another CDF parameter but I'm not sure how to do that. Can someone point me to the right direction? I tried using iPar but it doesn't work...
Say I have two parameter A and B. What I want to achieve is when A is turned on, B shows up. If A is turned off, B becomes hidden. A, on the other hand, is always shown just like any normal CDF parameter.
Thanks in advance!
  • skillUser
    skillUser over 13 years ago
    Hi Yaosan,
    I wrote a similar example for a SKILL Pcell, although not quite what you are looking for, since the example does not modify whether the parameter is displayed or not, but instead whether it is active or greyed-out.  Take a look at Solution 11509826 . Instead of "?editable" you would change "?display" I think.
    Hopefully this will be useful?
    Best regards,
    Lawrence.
  • dmay
    dmay over 13 years ago
    Here is an example:
        cdfCreateParam( cdfId
            ?name           "modelDisp"
            ?prompt         " Device Model"
            ?defValue      "N"
            ?choices        '("Invalid Model" "N" "NB" "NC" "User Defined")
            ?type              "cyclic"
            ?name           "model"
            ?prompt         " Model Override"
            ?defValue      "N"
            ?type              "string"
            ?display         "myCheckIsSchematic() && cdfgData->modelDisp->value == \"User Defined\""
            ?parseAsCEL     "yes"
    Derek
  • Yaosan Yeo
    Thanks for the quick reply and examples, Lawrence and Derek. I got it to work after checking out those examples. cdfgData is what I need to retrieve everything stored in CDF. Thanks!
