  3. i am having a problem with rodAssignHandleToParameter
  • Views 14396
Adhil
Adhil over 13 years ago
this is my code
procedure(createALPHA(cv w l)
  let( (rectRodObj)
  ;; create a rectangle on metal1 with x & y dimensions set by w & l
  rectRodObj = rodCreateRect(
      ?name     "myRect"
      ?cvId     cv
      ?layer    list("ALPHA" "drawing")
      ?width    w
      ?length   l
      ?origin   list(0 0)
  ;; create labels to show the w and l parameters
  ;; create a stretch handle for the width, in the X dimension, it
  ;; will display as "width = <value>" and change by 0.1 increments
  rodAssignHandleToParameter(
    ?parameter          "w"
    ?rodObj             rectRodObj
    ?handleName         "centerRight"
    ?stretchDir         "X"
    ?displayName        "width"
    ?displayExpression  "w"
    ?updateIncrement    0.2
  ); rodAssignHandleToParameter
  ); let
); procedure CCScreateBoxAndLabels
pcDefinePCell(
  list(ddGetObj("adhillib") "gp2_path1" "layout")
    (rows 1)
    (cols 1)
    (finger_width 0.10)
  let(((cv pcCellView) paramObj awidth alength bBox)
  paramObj = dbCreateParamInstByMasterName(cv "adhillib" "gp2_path" "layout" "inst1"
   list(0 0)
   "R0"
   1
   list(
    list("rows" "float" rows)
    list("cols" "float" cols)
    list("finger_width" "float" finger_width))
  bBox = paramObj~>bBox
awidth  = xCoord(upperRight(bBox)) - xCoord(lowerLeft(bBox))
alength = yCoord(upperRight(bBox)) - yCoord(lowerLeft(bBox))
println(awidth)
createALPHA(cv awidth alength)
cols = awidth/0.2
 but i am getting the error
*WARNING* rodAssignHandleToParameter: w is an invalid parameter
*WARNING* rodAssignHandleToParameter: command failed
I am trying to use the handle on rodrectobj with an alpha layer to extend the pcell within
Adhil
  • Adhil
    i changed the code i get this
    procedure(CCScreateBoxAndLabels(cv w l "dnn")
      let( (rectRodObj)
          ?name     "myRect1"
          ?cvId     cv
          ?width    w
          ?length   l
          ?origin   list(0 0)
        ?parameter          "w"
        ?rodObj             rectRodObj
        ?stretchDir         "X"
        ?updateIncrement    0.1
      ); let
    pcDefinePCell(
      list(ddGetObj("adhillib") "encapRodPcell" "layout")
        (w 0.2)
        (l 0.4)
      let( ((cv pcCellView))
        CCScreateBoxAndLabels(cv w l)
    cols = w/0.2
       list(0 0)
       "R0"
       1
       list(
        list("rows" "float" 1.0)
        list("finger_width" "float" 0.1))
      ); let
    the code compiles without errors, but the handle doesn't get assigned
    Adhil
    Adhil,
    Did you resolve this, given your other question? (the one I answered with the lambda)
  • skillUser
    skillUser over 13 years ago
     Hi Adhil,
    This code appears to work fine - I copied this and created something for the cell "gp2_path" that I could use with the code.
    Have you made sure that the "Stretch Handles" are turned on in the Display Options form?
    Hopefully this helps?
    Lawrence.
  • Adhil
    Hi Andrew and Lawrence
    Sorry for the late reply, but the code is working.I was not aware that the "Display stretch handles" was off. On the otherhand, thanks Andrew for your previous code, although i hope you could help me understand how it works.
    Thanks alot
    Adhil
    Adhil,
    I already gave an explanation in the other post...
