  3. Skill to turn off ruler selection in Cadence 6.1 layout
  • Replies 11
  • Subscribers 150
  • Views 20871
LongTimeNovice
LongTimeNovice over 13 years ago
Hello.
 I'm trying to write some Skill code that will turn off ruler selection in Virtuoso 6.1 layout.
 When I do it manually, this appears in my CDS.log file:
 _pteHiGuidePropagateSelectability(dwindow('pteGuidePalette3) "Rulers" nil)
 pteGuidePalette3 is specific to the window in which I run the command.  It won't work in any other window, for instance pteGuidePalette10.
 Is there a way to use the command such that it will turn off ruler selection in all windows?  Is there a different command to do this?  Otherwise, is there a command that will determine the palette number of a given window?
 Thank you!
Steven.
  • LongTimeNovice
     Thank you, Andrew!  And thank you, TeeBro and dmay as well!
     Andrew, that last piece of code works perfectly and loads from my .cdsinit.  It's exactly what I need.  Thank you.
     Thanks also for the advice about the Cadence help tool.  I didn't realize it covered Skill.  That will be a big help.
     Thanks again, and have a great day.
     Steven.
