  3. how to specify the position of fields in a form
  • Subscribers 150
  • Views 14297
suzan
suzan over 13 years ago
I would like to create a form containing 4 buttons and specify the position of each button in the form. I wrote the following code:
 Form1= hiCreateAppForm(
?name 'Form1
?fields list(
        ConfigBouton
        1000:0
       500:500
        CompareBouton
        1600:0
        500:500
        AnalogBouton
        1000:1000
        500:500
        RFBouton
        1600:1000
        500:500
Each time I execute this code, I have the following error message " getSymbol: invalid field: nil"
Some one can tell me what is the right syntax to specify button positions and the kind of values that I should put?
suzan
    Suzan,
    It should be like this:
        ?name 'Form1
        ?fields list(
            list(ConfigBouton 1000:0 500:500)
            list(CompareBouton 1600:0 500:500)
            list(AnalogBouton 1000:1000 500:500)
            list(RFBouton 1600:1000 500:500)
    By the way, your buttons are enormous!
  • psill
    psill over 13 years ago
     You can stack the functions and the locations.
    procedure(myGuiMenu()
    hiCreateAppForm(
            ?name 'myMenuForm
            ?formTitle "Da Form"
            ?buttonLayout 'Close
            ?initialSize 500:500
            ?fields list(
    list(   hiCreateButton(
                    ?name 'ConfigBouton
                    ?buttonText "Config")                              0:0     100:30  50)
                    ?name CompareBouton
                    ?buttonText "Compare")                        125:0   100:30  50)
                    ?name 'Analog
                    ?buttonText "Analog")                           250:0   100:30  50)
    )); end of hiCreateAppForm
    ); end of myGuiMenu
  • suzan
    Thanks a lot for the answer
    Suzan
