  3. error using lxSetConnRef()
  • Views 13698
rainc
rainc over 13 years ago
I'm trying to use  lxSetConnRef() function to set the reference between schematic and layout.
After load the skill function, the map file are not work when generate the layout from source.
But when I select the map file in layout XL edit view, it works well.
What's the possible reason?Below are the function used:
  lxSetConnRef(
    LayLibName
    CellName
    "layout"
    "CELLVIEW"
    ?schLib SchLibName
    ?schCell CellName
    ?schView "schematic"
    ?mapFile "~/map/cellMap.txt"
  ) ;end lxSetConnRef
Thanks and Regards,
Rainc
  • skillUser
    skillUser over 13 years ago
    Hi Rainc,
    I have not tried this but have you tried the ?mapFile argument without the "~", in other words use a fully qualified path, or use the simplifyFilename function to substitute for the "~".
    Hope this helps.
    Lawrence.
