  3. CDF data structure 'flattened'
  • Subscribers 150
  • Views 8708
tailsnaf
tailsnaf over 13 years ago
I have been writing some skill code to extract information from a cell's cdf - but I see a mismatch between the docs and the way some information is stored in the skill code - it seems the simInfo part has all of it's data 'flattened' into a string, and I cannot access the parameters of simInfo.
 I am using IC 6.1.5-65b
So If I do the following, on the cdf of the vpulse component from analogLib I get:
cdf~>?
(buttonFieldWidth doneProc fieldHeight fieldWidth formInitProc
    id parameters promptWidth simModels type
    paramLabelSet opPointLabelSet opPointLabelSet simInfo paramEvaluate
    paramSimType paramDisplayMode netNameType termSimType termDisplayMode
    instNameType instDisplayMode
When I look into simInfo, I get a flattened view - as when I do:
cdf~>?simInfo~>?
I get an error:
*Error* get/getq: first arg must be either symbol, list, defstruct or user type - ""
So instead if I just get the value of simInfo, all the information is there as a 'string'
cdf~>simInfo
(nil auLvs (nil propMapping nil namePrefix "") hspiceD (nil netlistProcedure hspiceDCompPrim_vpulse instParameters dc(acm acp v1 v2 td
    tr tf pw per
componentName vsrc termOrder (PLUS MINUS) propMapping
(nil) namePrefix "V" source t
termMapping (nil PLUS "" MINUS "(FUNCTION minus(root(\"PLUS\")))") noPortDelimiter t
) otherParameters (fundname noisefile FNpairs F1 N1
    F2 N2 F3 N3 F4
    N4 F5 N5 F6 N6
    F7 N7 F8 N8 F9
    N9 F10 N10
Is there a way to 'fix' the data structure format, so I cann access the sub-values of simInfo, like:
cdf~>simInfo~>termMapping
Thanks for any help.
  • berndf
    berndf over 13 years ago
     I guess you can do a
    cdfGetCellCDF( ddGetObj( libName cellName ) )->simInfo->spectre->termMapping
    which returns the term mapping as disembodied property list,
    which you should be able to assign new values to it.
    You have to do this on a netlister base, means for auCdl, auLvs,
    spectre, hspice in a sequence.
    You should be able to find a way to build a loop.
    The second possibility for the cell level CDF is simply use the
    SKILL function 'cdfDump'?
    It will return a file with the cell CDF which you can post process.
    Bernd
    The fundamental problem was that you were using ~> not -> (the first arrow could have been either, because that goes from the CDF object to the simInfo disembodied property list). Since the simInfo structure is a DPL, you have to use -> not ~> (I won't go into the differences here - but suffice to say, they behave differently when dealing with lists). Then as Bernd points out, you need to pull out the DPL for the simulator - e.g. cdf->simInfo->auCdl or cdf->simInfo->spectre.
  • tailsnaf
    Thanks Guys, the -> works.
    I did not know that ~> would not work for DPL structures - from the docs I thought that ~> was a 'super set' of the functionality that -> provided, as it works on lists of objects - but after looking now I see the docs do say that -> can be used to access the DPL structure.
     Thanks again!
  • tailsnaf
    Actually, I have a quick follow-up.
     If I have a variable called term - set as follows:
    term = "PLUS"
    And I want to read the term-mapping from the CDF of this - by doing:
    cdf->simInfo->spectre->termMapping->PLUS
    it returns:
    \:p
     Which is fine - however if I want to use the variable 'term' - is there a way I can do this directly - or do I have to use sprintf to build the 'access command', and then evalstring to evaluate it, like:
    sprintf(s, "cdf->simInfo->spectre->termMapping->%s" term)
    evalstring(s)
    Either:
    term='PLUS
    get(cdf->simInfo->spectre->termMapping term)
    or
    term="PLUS"
    get(cdf->simInfo->spectre->termMapping concat(term))
    The concat converts the string into a symbol. The get() function is similar to -> but it evaluates the argument rather than taking it literally.
    This is definitely better than constructing a string with an expression and using evalstring - which requires run time evaluation, and is completely unnecessary.
  • tailsnaf
    Excellent, that works nicely!
