  3. Post copy trigger in Cadence 5
  • Views 14983
tyanata
tyanata over 13 years ago
I have to create procedure which is doing certain things after object ( library, cell or view ) copying.
I searched the documentation and created the routine (based on Solution 11361080 ). The procedure works perfectly in Cadence 6 but in Cadence 5 not. It seems that post copy trigger does not work in Cadence 5 at all.
Just for example following procedure:
procedure(copyTriggerPrint(myFunction copyPhaseStr checkOffList supplementList otherFromSpecs otherToSpecs updateList retHint ctxList reserved "stgggggggx")
    let((retOK)
        retOK = t
        println("works YEEEEEEE")
        retOK
ccpRegTrigger("ccpPostCopyTrigger" 'copyTriggerPrint t)
envSetVal("ddserv.lib"  "enableCopyInDFII" 'boolean t)
In Cadence 6 when some object is copied, in CIW text appears "works YEEEEEE", in Cadence 5 it does nothing.
So my question is: is there some additional option which have to be switched ON in order Post Copy trigger to work in Cadence 5?
In the support page I found similar solutions:
Solution: 11696072 is marked for  Product Version: 5.1.41
Solution: 11361080 is marked for  Product Version: 5.1.41  and also is mentioned in the Solution that works on IC5141
In fact no one of the both solutions works in Cadence 5.
The our Cadence 5 version is IC5.10.41.500.151 .
Best regards,
tyanata
  • tyanata
     I succeeded to go little bit further in that issue.
    If I run icfb -nocdsinit  and then load my script in CIW before "Library Manager" opening, then the script works. If after icfb -nocdsinit first I open "Library Manager" and then load the script in CIW, the script does not work.
    For Cadence 6 there is not such dependence.
    Best regards,
    tyanata
    Two solutions - one would be to put:
     ddserv.lib enableCopyInDFII boolean t
    in your ~/.cdsenv or in <ICinstDir>/tools/dfII/local/.cdsenv
    The other would be to put a call to ddsCloseLibManager() in your code - provided the library manager is reopened after the envSetVal() it will be picked up.
  • tyanata
     Hello Andrew,
    Including the string ddserv.lib enableCopyInDFII boolean t in .cdsenv file, solves the problem.
    Just curious, why the string envSetVal("ddserv.lib"  "enableCopyInDFII" 'boolean t) in .cdsinit does not work in IC5, when automatic "Library Manager" opening is enabled.
    May be it must be mentioned in the both mentioned above solutions about that bug in IC5.
    Best regards,
    tyanata
  • dmay
    dmay over 13 years ago
    It is one of two things:
    1. The order that things happen. The .cdsenv file is read immediately when Cadence starts and the .csdinit is read later. It could be that the envSetVal runs AFTER the library manager is opened.
    2. Since the Library Manager is a separate process, the envSetVal in the Cadence session may not even help. The Libary Manager may simply get configured by the .cdsenv.
    The envSetVal is useful for setting values during your Cadence session in custom Skill code. The .cdsenv is the best place to set variables for startup.
    Derek
    I believe that if the library manager is started after the envSetVal() has been set in the main Virtuoso session, the library manager is started knowing that Virtuoso (icfb in this case) will take care of copying. The setting is only passed across at the time the library manager is started, not after it has been launched.
    You don't see the problem in IC615 because copying in DFII is enabled by default (but it wasn't in IC5141).
