  3. Change colour of layout window when switching between edit...
  • Replies 7
  • Views 3771
Change colour of layout window when switching between edit/read mode
blankman
blankman over 13 years ago
Hi All,
Im looking to write some code to change the colour or appearance of the layout window in some way when switching back and forth between edit mode and read mode. Im using IC6 and find it less obvious to see if a cellview is editable as compared to IC5. Is it possible to do this? I've had a look into editing window properties, but have run out of leads following this up in the documentation. Any help/suggestions appreciated.
Brian.
    Brian,
    geGetEditCellView([winId])~>mode (or geGetWindowCellView([winId]) depending on whether you wanted the edit-in-place cellView or the root window cellView). This is exactly the same in both IC5 and IC6.
  • blankman
    Thanks Andrew, is it possible then to change the colour of the actual window itself to indicate whether the cellview is editable or not, for instance have darker window borders for read, and lighter borders for edit, or something like that.
    I've had a look through the window properties with the below, but no mention here of any colouring configuration.
    geGetEditCellViewWindow(geGetEditCellView())~>?
    Brian.
    Brian,
    I was wondering how you were proposing to do that bit (by the way, geGetEditCellViewWindow(geGetEditCellView()) is a bit of a complicated way of doing hiGetCurrentWindow()). You can't change the background colour of the window, nor can you change  the colours of other aspects of the window. The banner is down to the window manager.
    So I don't believe this is possible. You could add a banner label, but to be honest that's not really any different from it saying "Editing" or "Reading" in the window banner, I guess.
    One idea might be to do:
    win=hiGetCurrentWindow()
    win->dimmingScope="all"
    win->dimmingIntensity=50
    By turning dimming on for everything, you could distinguish it - but it might be annoying...
  • blankman
    Thanks Andrew, I've written the code below, i'll give it a test run for the time being and see if I can get used to it. Another option would be to set cross cursor for edit, and normal cursor for read. But how would I go about setting this without the need for a bindkey? I'm assuming as an environment variable, but can I use when and if statements in the .cdsenv file? For instance if in edit mode set "layout    cursorShape    boolean    t", and if in read mode set "layout    cursorShape    boolean    nil"?
    procedure(BSdimEditRead()
            if(geGetEditCellView()~>mode == "r"
                    then    _leChangeEditMode("a")
                            hiGetCurrentWindow()->dimmingScope="eipSurround"
                    else    _leChangeEditMode("r")
                            hiGetCurrentWindow()->dimmingScope="all"
    hiSetBindKey("Layout" "<Key>space" "BSdimEditRead()")
    Brian.
    Brian,
    The cursor could be changed with hiGetCurrentWindow()->cursorShape=t (or nil for the normal cursor).
    You could use deRegUserTriggers("maskLayout" ...) to define a trigger. Both the "app" and "postInstall" trigger get called. So doing:
    procedure(myPostInstTrig(args)
      args->window->cursorShape=(args->accessMode=="r")
      hiGetCurrentWindow()->dimmingScope=if(args->accessMode=="r" then "all" else "eipSurround")
    deRegUserTriggers("maskLayout" nil nil 'myPostInstTrig)
    deRegUserTriggers("maskLayoutXL" nil nil 'myPostInstTrig)
  • blankman
    Andrew, this is new coding territory for me, very handy to know, thanks, i've been messing around with your code and have come up with the below. This will do the trick nicely
    Brian.
    procedure(myBSPostInstTrig(args)
    then drSetPacket("display" "nwel" "blank" "thickLine" "purple" "purple")
    hiRedraw()
    else drSetPacket("display" "nwel" "x" "thickLine" "purple" "purple")
    hiRedraw()
    deRegUserTriggers("maskLayout" nil nil 'myBSPostInstTrig)
    deRegUserTriggers("maskLayoutXL" nil nil 'myBSPostInstTrig)
