  3. Is it possible to make autoAbutment with shapes with StrongConnection...
  • Views 13234
Is it possible to make autoAbutment with shapes with StrongConnection?
Slayer
Slayer over 13 years ago
I've found strange situation during autoAbutment, that when shapes has weakConnection autoAbutment works fine, but in case when shapes has strongConnection, align of objects will be relative to first elemеnt in pin list.
There is my small test case. Create the simplest object which will be have schematic and layout views. On schematic view objects will have only one pin. For layout view use code with weakConnection:
[CODE]
let( (DseCellLibrary pcellId)
   DseCellLibrary = "test_lib"
   unless( ddGetObj(DseCellLibrary nil nil nil nil "a")
      error("Couldn't open library %L" DseCellLibrary)
  pcellId =  pcDefinePCell(
      list( ddGetObj(DseCellLibrary nil nil nil nil "a") "myTest" "layout")
      /* Default Parameters
     let(( pcCV p1 p2 netId termId pinId
     dbCreateRect(pcCellView "active" list(0:0 6:4));
     p1 = dbCreateRect(pcCellView "m1" list(0:0 1:4));
     p2 = dbCreateRect(pcCellView "m1" list(5:0 6:4));
      netId = dbMakeNet(pcCellView "p1");
      termId = dbCreateTerm(netId "p1" "inputOutput");
      pinId = dbCreatePin(netId p1);
      pinId~>accessDir = list("top" "bottom" "left" "right");
      netId = dbMakeNet(pcCellView "p2");
      pinId = dbCreatePin(netId p2);
      ;dbAddFigToPin(pinId p2);
      dbReplaceProp(p1 "abutAccessDir" "list" list("left") );
      dbReplaceProp(p1 "abutClass" "string" "aaa");
      dbReplaceProp(p1 "abutFunction" "string" "abutTest");
      dbReplaceProp(p1 "vxlInstSpacingDir" "list" list("left") );
      dbReplaceProp(p1 "vxlInstSpacingRule" "float" 2.0);
      dbReplaceProp(p2 "abutAccessDir" "list" list("right") );
      dbReplaceProp(p2 "abutClass" "string" "aaa");
      dbReplaceProp(p2 "abutFunction" "string" "abutTest");
      dbReplaceProp(p2 "vxlInstSpacingDir" "list" list("right") );
      dbReplaceProp(p2 "vxlInstSpacingRule" "float" 2.0);
     );end let 1
   );edn pcdefine
   dbClose( pcellId )
);end let2
[/CODE]
 And check autoAbutment.
After that recompile pcell with storngConnection:
[CODE]
   DseCellLibrary = "tsmc18_test"
      ;netId = dbMakeNet(pcCellView "p2");
      ;termId = dbCreateTerm(netId "p1" "inputOutput");
      ;pinId = dbCreatePin(netId p2)
      ;pinId~>accessDir = list("top" "bottom" "left" "right")
      dbReplaceProp(p1 "abutClass" "string" "nmos_uhv");
      dbReplaceProp(p2 "abutClass" "string" "nmos_uhv");
     );end let 1
   );edn pcdefine
   dbClose( pcellId )
);end let2
[/CODE]
And check it again. And you will see, that autoAButment works not correctly. And my question how I can avoid this situation?
P.S. for autoAbutment function use simplest skill code, like this:
[CODE]
 procedure(abutTest(ti ri tp rp dir cont event @optional group)
   let(
        ret
      (case event
         ; Return abutment spacing.
         (1
           ret = 0.0;
       ret;
         ); 1
         ; Reset pins to old shapes.
         (3
       ret = t;
           ret;
         ); 3
         ; Figure out what to do with all the pins.
         (2
       ret = t;
           t;
         ); 2
         (t ; Anything else return a nil
          ret = nil;
         );t
      );end case
      ret;
   );end let
);end procedure
[/CODE]
