  3. Regarding CDF Associated with Pcell
  • Subscribers 150
  • Views 13707
poiuytrewq
poiuytrewq over 13 years ago
 Hi
I want to create a Pcell with the following features.
Field that are in the  Parameter Field
1 . Field (Cyclic Field)  : In the Cyclic fields there should be Metals M1 , M2 , M3 , M4 .
2. Width Field :
3. Length Field :
 The Requirement is : If  You Select  M2 , the Pcell Should have M1 and  M2 Dummy Exclude layers with the given Width and length
If i select M4 then the Pcell should have M1, M2, M3,  M4 Dummy Exclude layers with the Given Width and length
I have create the Cyclic Field , Width field , Length field using Tools --> CDF  --> copy
I am confusing,  How to link with the layout and CDF . What should be drawn in the layout ?
I am not getting the Required output and layers.
  Pls suggest the flow.
Siva
  • Sarvani
    Sarvani over 13 years ago
     Hi siva,
                 First you need to create pcell layout with those fields.  You can do it either using SKILL or Graphical pcell editor( Tools~> pcell for 5X versions). And then you need to set CDF parameters for that cells. Please go through the installDirectory/doc/pcellref document for creating pcells.
