  3. Changing instance properties though SKILL
  • Replies 13
  • Subscribers 153
  • Views 40047
soathana
soathana over 14 years ago
Hi everyone I am using SKILL to generate a schematic.
So I am using schReplaceProperty function, but i have some problems. How can I get the names used for the instance parameters? The way i do it is call:
inst=dbCreateInst(...)
inst=list(inst)
schReplaceProperty(inst "name" "value")
So for  width appearing (in Property editor and edit object properties) "Total Width" this is not the case. Apparently When I insert for name  "Total Width" i get a user property named Total, apparently it does not like space :)
ideas?
thanks,
Sotiris
  • Jynee
    Jynee over 9 years ago
    Thanks Andrew. Now I get it. :)
    Why not all CDF parameters for a cell appearing in inst~>prop? Do you know how Cadence determines which prop to be included in inst~>prop?
    ~ShyJiun
    All CDF parameters don't appear in inst~>prop because that only contains actual property objects on the instance. The inst~>paramName lookup is a convenience operator which (in Analog netlisting mode) gives the overlay of the instance property value or the CDF default if not found. When you create an instance (through the schematic or layout create instance commands) it doesn't normally store the value of each CDF parameter on the instance unless it is different from the default. This is to avoid storing lots of unnecessary information on each and every instance (which takes more space), although this behaviour can be overridden per CDF parameter by the setting of the storeDefault attribute of the CDF parameter. If this is set to "yes", then the value of the parameter will be stored as an instance property even if it is the same value as the default.
  • Jynee
    Thank you, Andrew. You cleared all question mark in my brain.
    Thanks again. :)
    ~ShyJiun
