  3. Layout display screen resolution!!
  • Views 17776
bharath006
bharath006 over 13 years ago
  Is there a way to fit the layout window to the display resolution with a bindkey?? I am sure there must be a way to do it.Just that I am not aware of it. Can you please share it if you know.
My screen resolution is 1680 x 1050
Bharath.
    Bharath,
    This is something probably best handled via a binding in the window manager you're using - for example, in KDE 4.3.4, in the System Settings, under Window Behavior, Window Actions tab, I could change the Inner Window, Titlebar & Frame settings so that Alt Mouse wheel is set to Maximize/Restore - then if I hold down the Alt key and scroll the mouse wheel one may it maximizes, and in the other direction it restores the original size.
    Otherwise:
    hiResizeWindow(hiGetCurrentWindow() list(0:0 hiGetMaxScreenCoords()))
    would do it.
  • bharath006
    Thanks Andrew!! 2nd option worked perfect for my situation.
