  3. Ocean Script Error
  • Views 16226
Ocean Script Error
Adam86
Adam86 over 13 years ago
 When I try loading my ocean script below:
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design(     "/home/aalsaafi/simulation/working17-7/spectre/schematic/netlist/netlist")
resultsDir( "/home/aalsaafi/simulation/working17-7/spectre/schematic" )
path( "/CMC/kits/IBM_PDK/cmrf8sf/relDM/Spectre/models" )
modelFile(
    '("/CMC/kits/IBM_PDK/cmrf8sf/V1.6.2.4DM/Spectre/models/allModels.scs" "")
analysis('tran ?stop "10u"  ?errpreset "moderate"  )
option(    'dochecklimit  "no"
saveOption( 'useprobes "yes" )
saveOption( 'currents "selected" )
temp( 27 )
out=outfile( "/home/aalsaafi/simulation/working17-7/myResults.txt" "w")
run()
results()
selectResult( 'tran )
outputs()
fprintf(out "%s\t%5.2f\t%10.2f\n" VT("(/Vout_tran")))
close(out)
 simulation goes fine till it reaches the following error:
*Error* fprint/sprint: format spec. incompatabile with data-nil
<<<Stack Trace>>>
 Has this error came across anyone?
    Several things wrong here:
    1. Almost certainly there's no node in the circuit called "(/Vout_tran" - you probably meant:
      VT("/Vout_tran")
      So it will be returning nil as the first argument after the format string to fprintf
    2. The fprintf is expecting three slots - a string, and two floating point numbers. You're only passing one VT() call, which will produce a waveform. So that's almost certainly not what you want.
    3. There are too many close parentheses on the fprintf line
    4. Maybe you just want to use ocnPrint(?output out VT("/Vout_tran"))
  • Adam86
    Thanks Andrew
    Now I get this error
    *Error* close: argument #1 should be an I/O port (type template ="p")-nil
    <<<Stack Trace >>>
    close(out)
     The purpose of writng that script is to be able to get the data into matlab
    I would expect that to happen if you don't have a node called Vout_tran - because VT("/Vout_tran") will produce nil, and then ocnPrint(?output .. nil) will write nothing.
    So you should check what outputs() gives - does it list the node you're expecting? Get the script to do:
    pprint(outputs())
    newline()
    Note there's also a spectre toolbox for Matlab available in the MMSIM hierarchy - this means you can directly read the simulation results using the cds_srr() function in Matlab.
  • Adam86
     Sorry for botheing..
     I get this error now:
    <<<Stack Trace>>>
     I'm using Cadence 5.1.41
    Given that I can't see the current state of your script, it's rather hard to debug! I've no idea what you've actually changed it to. All that the error tells me is that you're passing nil to the close() function, and that's wrong - the variable shouldn't be nil..
