  3. Ocean script error - run() too few arguments
  • Replies 7
  • Views 4461
OceanDesign
OceanDesign over 13 years ago
I have a strange problem related to Ocean Scripts.
When I run my simulation in Virtuoso Analog Design Environment, it works perfectly. But when I use "Session -> Save Script" and create the Ocean script file "oceanScript.ocn" and try to call it in ICFB using
load "oceanScript.ocn"
I get one Warning and one Error.
1) *Warning* hiInsertMenuItem: All menu item must be unique. No item added.
I verified that this was related to the first line of the script file, where I have:
 ocnWaveformTool( 'wavescan )
2)  *Error* run: too few arguments (1 expected, 0 given) - nil
 I verified that this was realted to these two lines
analysis( 'dc ?saveOppoint t )
run()
 Could someone please help me figure out what is going on? The script is generated by Viruoso ADE and I haven't even touched it. But I keep getting these errors.
Thank you.
    My guess is that in both cases some local customization is messing things up - there's probably a trigger somewhere which is trying to add a menu (I'm not sure), and I suspect somebody has written their own SKILL function which is also called run().
    Try using "icfb -nocdsinit" to launch and see if that helps; this would avoid loading any customization and so should hopefully avoid the problem (if it's what I'm guessing it is).
    You could also try arglist('run) or pp(run) to see what the definition is (this may not work) - you'd have to do that in a normal "icfb" session to ensure any custom code is loaded.
  • OceanDesign
    Thanks Andrew for your reply.
    For arglist('run) I get:
    (commands)
    Version : IC5141 (IC5.1.41 USR5), LINUX
    and for pp(run) I get:
    pp: run is a read protected function and cannot be pretty printed
    nil
    For icfb -nocdsinit I get
    command not found
    and then starts exactly as if I have not used the option. I keep getting the same error messages.
    Any idea how I can resolve this?
    The arglist should return
    (@rest args)
    I checked in IC5141 USR5, so clearly you must have some customization. Presumably the customization is encrypted or in a context file, which is why you can't pp() the function.
    If "icfb -nocdsinit" does not work, my guess is that  you have a wrapper around icfb which doesn't allow you to pass arguments. If you type in the UNIX shell "which icfb" is it coming from <ICinstDir>/tools/dfII/bin ?
  • OceanDesign
    Thanks Andrew.
    When I type which icfb I get
    icfb: aliased to icfb_sub
    And when I type which icfb_sub I see a directory different than the one you mentioned.
    Is there still a way to get the Ocean Script working properly under these circumstances?
    Presumably - but hard for me to advise since I can't see what the "icfb_sub" script does. Maybe if you have a look in the script you can see who wrote it and contact them? From the name, my guess is that it submits it to your compute farm?
    Perhaps you can post the contents of icfb_sub here?
  • OceanDesign
    Thanks Andrew.
    I showed your comments to our support team and they suggested this:
     icfb_sub -sim -v 51.usr6 icfb -nocdsinit
    It now works perfectly.
    I was scratching my head for a while on what was wrong with my Ocean codes. But now the mystery is resolved!
    Again, thanks a lot!
    That's good! You may also want to suggest to your support team that they don't define a SKILL function called run(). We recommend that SKILL functions use an uppercase prefix, as that way it won't clash with a function from Cadence.
