  3. check on track
  • Views 14536
check on track
Rojalin
Rojalin over 13 years ago
hi,
I have some pins in the layout along with some tracks .I want to check if the center of the pin lie on the track.
for that i want to check output of a function should be an odd integer.
how to do this ??
    Your description is a little vague, but the relevant functions would be:
    center=centerBox(pinFig~>bBox) => return the centre of the pin figure - the pinFig would be pin~>fig (for example)
    dbGetOverlaps(cvId list(center center) ...)
    to find out what's under the point you've found.
    Not sure what you mean about it returning an integer, but oddp() will determine if an integer is odd or not.
  • Rojalin
    hi,
    if(yCoord(centerBox(obj~>bBox))/0.04) this is the conditional statement i want to put.If this output is an odd integer or not  i need to check.
    how to do this?
    So presumably oddp(round(yCoord(centerBox(obj~>bBox))/0.04)) will tell you this.
  • Rojalin
    hi, Thanks andrew but It did not solve my purpose, let me explain my purpose clearly. I have many pins in my layout. I want to chack ycoordinate of center of the pins at odd multiple of 0.04.If some pins are not at odd multiple of 0.04 then it should print that pin is not correct. Please suggest me how to achive this??
    It's still not clear. I've told you how to find out the coordinate of a pin figure, how to check that an integer is odd, and how to check that a coordinate is on top of some shapes. What more do you need to know? Are you just expecting me to write the entire code for you?
