  3. Polygon reentrant
  • Subscribers 150
  • Views 14436
Polygon reentrant
151515
151515 over 13 years ago
 I tried creating a polygon in skill using dbCreatePolygon
Error message:"polygon is reentrant" is popping up!
So,How to overcome this problem and create the polygon using the same points.
"Anyone please reply asap"
Thanks & Regards,
Sudha
  • marcelpreda
    marcelpreda over 13 years ago
     Hi there,
    For sure you can not use "the same points", the polygon coordinates have to be changed.
    The idea is that your polygon is a self intersectin polygon, and it is not OK.
    The best thing that you can do is to check if the polygon is reentrant before creating it,
    and if it is reentrant you jut print the coordinates to find the problem.
    For polygon checking you can use: geIsPolygonReentrant(cellView l_points )
    => t / nil
    BR,
    Marcel
