  3. How to open Code Browser
  • Views 14956
MOS007
MOS007 over 13 years ago
Hello Everyone,
How to open the Code Browser in cadence. I have trouble finding out all the child functions that are used by some of the bigger functions. What approach are you guys following? I am just trying to get the coordinates of the bounding boxes for all the different metal layers that exist in the layout.
Mosfet
  • dmay
    dmay over 13 years ago
    There are a few things you can use to help you find functions, but there isn't really a code browser. From a shell window you can run "cdsFinder" or from your CIW "startFinder". This interface will help you find skill functions and their basic usage.
    If you own a Skill Development license, you can profile the peformance of the code your run and then view a tree of this code. In most cases, if it is a Cadence built in command, you won't see much of a tree, but for your internal code you'll see a full tree. To run this, go to your CIW->Tools->Skill Development, then press the Profiler button. On the new interface, press the triangle button (start) and then invoke your top level Skill command. When the command finishes, press the stop button. Then press the tree button to get an interface to browse the tree. Right clicking on a command will give you the option to expand the tree.
    Another option is to turn tracing on. In your CIW, type trace(t). This will create an enormous amount of output to your CIW, so you only want to turn it on just before you run a command and then turn it off with untrace(). This will trace all the function calls that take place and show you the return values of the calls.
    There is also a new Skill IDE in 6.1.5, but I haven't used it and don't know if it will help you find commands.
    Derek
    Actually there is a code browser in the SKILL Development tools (it's been there for as long as I can remember) - without you having to run the profiler - but you'll only be able to browse your own code (essentially code that isn't read protected). Not that sure what you are trying to do here...
