  3. Add new metal layer
  • Subscribers 150
  • Views 15379
Add new metal layer
Michael85
Michael85 over 13 years ago
I would like to add M7 layer above the M6 layer automatically in the entire design.
in order to do that I need to create VIA M7-M6 between the to layers.
Is there a way to do that?
To cover M6 with M7 and create vias between them.
Michael
  • marcelpreda
    marcelpreda over 13 years ago
     Hi Michael,
    To copy M6 to M7 you may have a look at dbLayerOr() function.
    dbLayerOr(
    d_cellViewId
    t_layerName
    l_dbIdList1
    [ l_dbIdList2 ]
    [ x_numVertices ]
    I guess that you should descend down into the hierarchy on each cell do
    ;; open the lib/cell/view in "cv" variable
    m6_lpp = car(exists(lpp cv->lpps (lpp->layerName == "M6" && lpp->purpose == "drawing")))
    m7_list = dbLayerOr(cv "M7" m6_lp->shapes)
     ;;Now you will have the M7 shapes in m7_list.
     Eventually to improve the speed if  a lib/cell/view is used multiple times in the layout, and  you have already added M7 you have to skip the procedure next time (M7 is already there).
     Regarding via placing, I think that here you will need a more complex procedure.
    Anyway the question is: is a good idea to put M7 everywere over M6 ?
    If you already have some M7 shapes in the layout you may create unwanted shorts.
     Hope this helps,
    Marcel
  • Michael85
    Thanks marcelpreda.
    It works fine.
    Michaael
