  3. deRegUserTriggers
  • Views 14801
deRegUserTriggers
MLindig
MLindig over 13 years ago
I used deRegUserTriggers for "schematic" view type, but my trigger functions need some additional data which are available at the deRegUserTriggers call.
My question is how can I access the additional data from the trigger function?
Another question is: Can I put some extended (userspecific) context data to a schematic view?
I tried: (putprop deGetContext(window(4)) "some data" 'myUserCtxData) but it does not work :(
Thanks for help,
Michael
    Michael,
    Maybe you can explain a bit more about what you're trying to do. One thing you could do is store it as a property on the window object?
  • MLindig
    I need to add some specific hilighting in the schematic, where the data for the hilighting will come from different sources and depends on the selction of the source data. The selection of the hilighting source data will be done in a dialog, where I call geOpen(...) which triggers my preregisterd trigger function.
    But the hint with the putprop on the window object should solve my problem ;)
    Michael
