  3. removal of a sublist from a list
  • Views 15400
Rojalin
Rojalin over 13 years ago
hi,
I have a list of floating point numbers.I want to remove a sublist from this list.
Is there any skill procedure for it?
    Please show what the list looks like, and indicate what you want removed (and how you can determine what to remove) - and what you expect it to look like afterwards. It's always much clearer with an example.
  • dmay
    dmay over 13 years ago
    You can create a new list that is a subset of the original list by using "setof":
    myList = list(2.5 1.2 3.75 5.9 0.1)
    subList = setof(x myList x>2.0)
    subList2 = setof(x myList x>1.0 && x<5.0)
    If you want to remove items from myList can use "remove", but this will only remove one item at a time and you must store the results in a new list (remd will modify the original list). The problem you'll run into is that floating point numbers cannot always be matched exactly due to the nature of binary computers.
    newList = remove(1.2 myList)
    The above might not work if the original list contains 1.19999999999 instead of 1.2.
    Derek
