  3. Calculator skill function for sampling signal on varying...
  • Subscribers 150
  • Views 17893
Calculator skill function for sampling signal on varying pulse edge
daly
daly over 13 years ago
Hi there,
I have been trying unsuccessfully to use the built-in Cadence calculator functions to sample an analog signal at multiple times, based on a digital clock edge which comes at non-periodic times.  Has anyone had success using the functions such as "value", "sample" or "cross" to do this?  "cross" can get me the array of times I would like to sample, but I can't find a function that gives me the value of another analog waveform based on this array of times.
If there is no way to do it using the built-in calculator, I would like to write a custom SKILL calculator function to implement this functionality.  Does anyone have a similar example program that I could use as the starting point?
Thanks!
  • marcelpreda
    marcelpreda over 13 years ago
    Hi there,
    Let'a assume that in list l_times you have the time values for which you want to have the associated values.
    Do a foreach (or better mapcar) and using value() or sample() build a new list with the values , l_values.
    Now you will need to create two vectors and then the waveform:
    xV = drCreateVec('double l_times)
    yV = drCreateVec('double l_values)
    thewave = drCreateWaveform(xV yV)
    My assumption was that on x/y axis you have type 'double .
     For dr* functions used above you may have a look on skartistref.pdf  (Virtuoso Analog Design Environment SKILL Language Reference) documentation.
    Best Regards,
    Marcel
  • daly
    Marcel - thanks so much.  Your tips led me in the right direction and I was able to get the code working!
