  3. form returning to main function
  • Subscribers 150
  • Views 13630
Rojalin
Rojalin over 13 years ago
hello,
I want  to write a code for a function which will create a form in which many fields are there.In each field i want a cyclic field of many lists..where user will enter there  one of their choice.after this it will return to main  function where entered field given by user will execute some other functions.
For example,
my main function will create a form named My form which has different field named m1,m2,m3 like this.m1 is having m1_1,m1_2,m1_3 in cyclic field.m1_1 is a list of floating numbers defined in my main function.
 So anyone can help me.
  • Quek
    Quek over 13 years ago
    Hi Rojalin
    Hope that this is what you need. Please load the form and press F10 in ciw.
    Best regards
    Quek
    procedure( myForm()
       let( (m1)
          m1=hiCreateCyclicField(
             ?name 'm1
         ?prompt "m1"
             ?choices list("m1_1" "m1_2" "m1_3")
          ) ;hiCreateCyclicField
          hiCreateAppForm(
             ?name 'sampleForm
             ?formTitle "Testing"
             ?fields list(m1)
             ?callback "sampleCallback(hiGetCurrentForm())"
          ) ;hiCreateAppForm
          hiDisplayForm('sampleForm)
       ) ;let
    ) ;procedure
    procedure( sampleCallback(myForm)
       let( (m1)
          m1=myForm~>m1~>value
          printf("User selected %s\n" m1)
       ) ;let
    ) ;procedure
    hiSetBindKey("Command Interpreter" "F10" "myForm()")
    sampleform.il
