  3. How to revert to default value using skill?
  • Subscribers 150
  • Views 14285
Reinice
Reinice over 13 years ago
I have an old process instance which has a property
| model | nch_33 |
Then I changed its master to new process instance (“nch_hvt”). But the Model name of the new process instance is still “nch_33”
| Model name | nch_33 |
I want to revert “Model name” to default (nch_hvt) using skill and not GUI. How can I do this?
Thanks and Regards,
Reiniel
  • marcelpreda
    marcelpreda over 13 years ago
    Hi Reiniel,
     Most likelly your cell has a CDF param named "model",  just try to output inst->model in your script.
    If it is so, the you can do inst->model = "nchhvt", after you have changed the cell name (master).
    If inst->model is nil, then you have to look in your CDF paras tabel to find the real name of the property.
    Best Regards,
    Marcel
  • Reinice
    Hi Marcel,
    Your suggestion works fine. I think my question is resolved. = )
    Thanks and Regards,
    Reiniel
