  3. How to plot all corners using ocean xl?
  • Views 14532
Reinice
Reinice over 13 years ago
Good Day.
I have an ocean script that executes all corners that have been set up. Problem is that the last corner run is the one only plotted everytime I execute it. Theres no issue on the corners, only in plotting. Here's the function/s I used for plotting:
First used to plot corners:
plot(
getData("/AVDD33")
getData("/BGOUT")
Second used to plot corners:
nets = list("/AVDD33" "BGOUT")
let( (waves)
waves = foreach(mapcar net nets v(net))
awvPlotWaveform(
newWindow()
waves
?expr nets
Thanks and Regards,
Reinice
  • Reinice
    BTW, I' am using version 6.1.5
    Thanks and Regards,
    Reinice
  • Reinice
    I think I've already resolved this issue. But I' am not sure if my analysis is correct.
    I think it's the corner combination of my script. Before I have the same value for all "variable"
    ocnxlCorner("corner1"
    ("variable" "temperature" "-40")
    ("variable" "AVDD" "3.3")
    ("variable" "Cload" "2p")
    ("modelGroup" "\"top_ss"")
    ocnxlCorner("corner2"
    ("modelGroup" "\"top_tt"")
    ocnxlCorner("corner3"
    ("modelGroup" "\"top_ff"")
    and when I set up my "variable" like this
    ("variable" "temperature" "-40 25 125")
    ("variable" "AVDD" "2.97 3.3 3.63")
    All corners have been plot out.
    Question now is why it did not plot all corners(only corner3) before even if "modelGroup" have different values?
    Thanks and Regards,
    Reinice
