  3. Moving a schematic object without loosing the connectiv...
  • Views 14361
Moving a schematic object without loosing the connectivity
Leo John
Leo John over 13 years ago
I'm trying to move a set of schematic objects using skill. I'm using the function schStretch so that I don't loose the connectivity.
Suppose, I've a mos instance in a schematic. Using the below commands, I'm replicating the scenario.
css()~>xy => (1.0 1.0) ; the initial location of the instance
tr = list( 1:1 "R0" )
schStretch( list(css()) tr )
css()~>xy =>(2.0 2.0) ; moved by (1 1) specified in the transform.
But, when the transform is, say
tr = list( 1.008:1 "R0" )
css()~>xy =>(2.00625 2.0)
I was expecting the location to be (2.008 1).
Why is this happening? Isn't this what's expected out of this command? If not what's the command to move an object(all sch objects) by a distance without loosing the connectivity?
Any help would be appreciated.
Leo
    Leo,
    The underlying database uses integers to represent coordinates and has a concept of "database units" and "user units".
    For schematics the user units are usually "inch" and there are 160 database units per user unit. For example:
    cv=geGetEditCellView()
    cv~>userUnits
    "inch"
    cv~>DBUPerUU
    160.0
    Because of that, you cannot represent a user unit of 2.008 in the database, and so it rounds to the nearest database units - hence 2.00625.
  • Leo John
    Thanks a lot for the quick reply and resolving the confusion.
    Leo
