  3. SKILL code to generate lower routes with same path properties...
  • Replies 24
  • Views 24285
SKILL code to generate lower routes with same path properties of the selected path
Neeraj Vardhan
Neeraj Vardhan over 13 years ago
I am trying to generate lower routes with same path properties as of the selected path. Can any one assist me how can i do it using SKILL.
    What do you mean by "lower routes"? Your requirement is rather vague...
  • Neeraj Vardhan
    Hi let me give an example..... i have a metal route in M7 layer , i want to generate M6-M1 path with same properties of M9...i mean a metal stack...
    foreach(newLayer'("M6" "M5" "M4" "M3" "M2" "M1")
      newPath=dbCopyFig(origPath origPath~>cellView list(0:0 "R0"))
      newPath~>layerName=newLayer
    Something like that. This is assuming that the original path is in the variable origPath. The third arg to dbCopyFig is the transformation - and it leaves it in the same location.
  • Neeraj Vardhan
    Ya the original path is in the variable origPath. Thanks a lot Adrew...
  • Neeraj Vardhan
    Hi, can you let me know how can i copy a path then edit the layer and then place it at the same coordinates
    Thanks & Regards
    I'm confused. Didn't I explain how to do precisely that in my append on Monday?
  • shashikumar22
    shashikumar22 over 13 years ago
    Hi Neeraj,
    I have used the script mention by Andrew and modified it little bit. Just load the script in CIW and select the Metal layer you want to copy and hit Ctrl+t. I have used only 3 metal ie M0, M1 and M2.
    procedure(metalStackUP()
    let((newPath MBL)
    x=css()
    MBL=x~>layerName
    if( MBL == "M0" then y="M1"
        else
    y="M2"))
    newPath=dbCopyFig(x nil list(0:0 "R0"))
    newPath~>layerName=y
    hiSetBindKey("Layout" "Ctrl<key>T" "metalStackUP()")
    You shouldn't really use css() in your code; this is a private SKILL function which was added as an internal debugging aid by one R&D group; there's always the chance it may get removed at some point.
    I tend to use it only when quickly typing stuff in the CIW - for code use car(geGetSelSet()) instead to ensure that your code is future proof.
  • shashikumar22
    Thanks Andrew,
  • Neeraj Vardhan
    Hey thanks ShashiKumar...:-)
