  3. Running multiple AC simulations with multiple stimulus files...
  • Views 17083
Running multiple AC simulations with multiple stimulus files using Ocean Script
lartola
lartola over 13 years ago
Dear all,
I would run multiple AC simulations (with Spectre simulator) using an Ocean Script. However I would change for each loop the stimulus file. I don't know how to specify the changing of the name of the stimulus file for each run.
Thanks in advance for  your help
laurent
    simulator('spectre)
    design(...)
    analysis('ac ...)
    foreach(stimFile '("file1.scs" "file2.scs" "file3.scs")
       stimulusFile(stimFile)
       run()
       ; process the results as you wish
    Something like that?
  • lartola
    Actually, I would make a loop for strong number of stimulus files (10-1000 around). I've thought about of loop depending on n with "n" defines in the name of the stimulus file. Is it possible ? Thanks in advance Andrew Laurent
     Of course:
    for(i 1 1000
      stimulusFile(sprintf(nil "stimFile%d.scs" i))
      run()
    Use something like sprintf() to build the filename as you go along.
  • lartola
    Andrew, thanks so much for your answer I will work in this way. Regards Laurent
  • lartola
    Dear Andrew,
    i've worked on the ocean script for running multiple AC simulation as you said me. However I get a problem. Actually the loop works perfectly but the simulator seems don't used the correct stimulus file. If I check the netlist file all of the used stimulus are present but when I check the simulated data something seems wrong.
    Actually, the simulator seems add loop after loop each the stimulus files. I Need to perform a reset for each run or something like that ? Following the current ocean script i'm using:
    ;------------- Initialization -------------------------------------
    simulator( 'spectre )
    design( "**********/spectre/schematic/netlist/netlist")
    definitionFile( "models.scs")
    stimulusFile( ?xlate nil "/*******/spectre/schematic/netlist/_graphical_stimuli.scs")
    temp( 23.0 )
    TotalRun = 3
    ;------------- Automatic electrical runs -------------------------
    Tempfile1 = outfile( "/************net6_testpostprocess.txt" "w")
    Tempfile2 = outfile( "/************net7_testpostprocess.txt" "w")
    for(i 1 TotalRun
    stimulusFile( ?xlate nil sprintf( nil "/*********Stimulis_test_MUSCA_SETcurrent_SRAM_%d.txt" i))
    analysis('tran ?stop "0.055E-6" ?method "trap")
    envOption( 'analysisOrder list("tran"))
    option( 'temp "23.0" )
    run()
    results()
    selectResult( 'tran )
    plot(getData("/I4/A") getData("/net06") getData("/net7") getData("/WL") getData("/BLbarre") getData("/BL"))
    ocnPrint( v("/net06") ?output Tempfile1 ?numberNotation 'none ?precision 15 ?width 20)
    ocnPrint( v("/net7") ?output Tempfile2 ?numberNotation 'none ?precision 15 ?width 20)
    close(Tempfile1)
    close(Tempfile2)
    printf("Simulation complete")
    Thanks in advance for your time Regards Laurent
     Hi Laurent,
    The problem is that each time you call stimulusFile() with a different file, it adds to the list of stimulus files. The usual way of solving this with OCEAN is to use the delete() function to reset the particular item (you can delete analyses, saves etc), but unfortunately delete('stimulusFile) hasn't been implemented yet.
    This is described in my solution 1026408 on Cadence Online Support. The workaround is to use::
    asiSetEnvOptionVal(asiGetCurrentSession() 'stimulusFile list(stimFile))
    where stimFile is the file you want to set. This will override any previous stimulus file lists that have been set.
