  3. INTERNAL ERROR (BADRULE) in SKILL lint report
  • Views 14183
Eduardas
Eduardas over 13 years ago
Hi, All
SKILL lint is run on:
Program: @(#)$CDS: virtuoso version 6.1.5 04/06/2012 20:54 (sjfdl235) $
Sub version: sub-version IC6.1.5.500.10 (32-bit addresses)
I get following in SKILL lint report file:
INTERNAL ERROR (BADRULE): .../myProg.il, line 27 (FuncName) :
    Error occurred while checking sort(lns 'lambda((a b) ((\& \& \&) > (\& \& \&)))):
    *Error* makeTable: argument #1 should be either a string or a symbol (type template = "Sgx") - lambda((a b) (length(a) > length(b)))
    Please file a bug report.
Actually, this line is: lns=sort(lns 'lambda((a b) greaterp(length(a) length(b))))
Can anybody take a look?
Regards, Eduardas
    Eduardas,
    Rather coincidentally one of my colleagues created a solution in the last day or two on exactly the same problem.
    The Lint problem has been fixed in IC616, however, if you turn on the "Performance" switch on the SKILL Lint form, you'll get an output like this:
    HINT (LAMBDA1): ~/skill/forum.il, line 9 (bug) : lambda and nlambda statements do not need to be quoted : 'lambda((s1 s2) let((b1 b2) (b1 = (\& \& \&)) (b2 = (\& \& \&)) ...))
    The solution is to remove the ' before the lambda. It's not necessary, and without this SKILL Lint won't fail with the BADRULE error.
  • Eduardas
    Andrew,
    Thanks, it works.
    Eduardas
