  3. Move, Stretch, Copy done by minimum spacing
  • Subscribers 150
  • Views 14699
Sarvani
Sarvani over 13 years ago
Hi All,
           When I move(or stretch) the object's in Layout then it should not move less then minimum spacing to sorrounding objects. How can I get this?
Thank You,
Sarvani.
  • Quek
    Quek over 13 years ago
    Hi Sarvani
    Would you please let us know if you are using IC5141 or IC61?
    For IC615, you can use "Edit->Quick Align" function to move a shape to another shape so that their separation is 1 minSpacing value.
    In IC5141, you can use "Rule Move" cmd in "Options->Toolbox".
    Best regards
    Quek
  • Sarvani
     Thank you Quek. Now I am using both 61 and 5141 versions. And your suggestion's work's well and meet's my requirement in both version's.
    Thank You,
    Sarvani.
