  3. pop up for a program error
  • Views 15655
KKANDOTH
KKANDOTH over 13 years ago
 Hi All,
 I want to build a program which has a user alert facility as soon as it find some error while executing. For example if there is a program like this
procedure(testing()
a = "try"
b = 2
c=a*b
)  This program will find an error at line c = a*b. and throw a *ERROR ..... message in icfb.log. I want to have a pop up window which alert the user as soon as it exit. I am using a try1=errset(testing) now. According to try1 value , (t or nil) i can find if the program executed or not. but it will suppress the error message in ICFB.log
 Thank You,
Krishnan
    Krishnan,
    This does what you want:
    procedure(myErrorHandler(info)
      hiDisplayAppDBox(
       ?name 'myErrorDialog
       ?dboxBanner "Error occurred"
       ?dboxText info
       ?dialogType hicErrorDialog
       ?buttonLayout 'Close
       ?dialogStyle 'modal
    ilAddTopLevelErrorHandler('myErrorHandler)
    By the way, if you use errset, you can either pass t as the second argument to errset, and then it will still print the error message. Or you can get the message info by accessing errset.errset . For example:
    errset(testing() t)
    *Error* times: can't handle ("try" * 2)
    unless(errset(testing())
      printf("GOT THIS: %L\n" errset.errset)
    GOT THIS: ("times" 0 t nil ("*Error* times: can't handle (\"try\" * 2)"))
    You can find out more on errset.errset in the documentation for errset().
  • KKANDOTH
    Thank You very much for your help. " errset(testing() t) " solved all my problems
    Thank You,
    Krishnan
