  3. print SKILL(batch mode) output in unix terminal
  • Views 2862
KKANDOTH
KKANDOTH over 13 years ago
Hi All,
 I am running a skill script in batch mode and need to print the out put in unix terminal. for example
procedure(TRY()
a=0
b=1
c=a+b
);procedure
here I need to print the value of c on terminal like VALUE=1 . I am trying with csh(print) command but its not working. Is this possible or I am trying something which is not possible ??
Thank You,
Kandoth
  • dmay
    dmay over 13 years ago
    One simple way is to create a string with the sprintf command and then pass the string to the system command which will run that string in the Unix terminal from which virtuoso was invoked.
    system(sprintf(nil "echo VALUE=%d" a+b))
    Note that %d will only handle integers, you'll need %f for floats.
    Derek
  • KKANDOTH
     Hi Derek,
    In Case if I want to print only a text message(ex: "COMPLETED SUCCESSFULLY") then , do i need to use sprintf ?
    Thank You,
    Kandoth
  • dmay
    No, you could simply do this:
    system("echo COMPLETED SUCCESSFULLY")
    Derek
  • KKANDOTH
     Derek,
    Thank You very much for your help..
    Thank You,
    krishnan
