  3. How to remove the new line character
  • Subscribers 150
  • Views 19690
Danilo P
Danilo P over 13 years ago
 Hi all,
is there a way to remove the newline character at the end of lines read from files?
I did it with:
while(gets(line fileIn)
   if( .... then   mystring = car(parseString(line "\n") ..............)
 Is a skill function available to do that?
thank you
  • marcelpreda
    marcelpreda over 13 years ago
    from what I know there is no skill function to do it straight forward.
    Best Regards,
    Marcel
  • skillUser
    skillUser over 13 years ago
    Hi Danilo,
    I've used the method that you noted, but you might also do something like the following:
      when(rexMatchp("\n$" line)
        line = strncat("" line strlen(line)-1)
      ); when the line ends with a carriage return, remove it
     I don't know how this compares with the other approach, in terms of speed/resources, so I'll leave that as an excercise for the interested reader ;-)
    Lawrence.
    Or you could use (in IC61X):
    ; create this pattern once
    cr=pcreCompile("\n")
    ; as you read in each line
    mystring=pcreReplace(cr line "" 0)
    This is using the Perl Compatible Regular Expression functions, storing the compiled pattern object in a variable, and then using that each time you want to replace carriage returns with nothing.
  • Danilo P
     Thank you all for the suggestions.
    Danilo
