  3. PathSegments not connected
  • Views 14235
Adrian Nistor
Adrian Nistor over 13 years ago
My problem is reduced to 2 simple cases:
Case1:
dbCreatePathSeg(cvId "metal" 0:0 3:0 0.6 "truncate" "truncate")
dbCreatePathSeg(cvId "metal" 3:0 6:3 0.1 "custom" "custom" list(0.425 0.425 list(0.3 0.3 0.425 0.3 0.3 0.425)))
I have the result from first attached file, where if I move the mouse over any of the 2 segments, entire path is higlighted or if I click, entire path is selected;
Case2:
I want to have the edges of the diagonal segment on a grid of 0.05:
dbCreatePathSeg(cvId "metal" 3:0 6:3 0.1 "custom" "custom" list(0.425 0.425 list(0.3 0.3 0.45 0.3 0.3 0.45)))
In this case the segments are not "connected" anymore, probably because the width of the second one is different than what he expects.
The question:
Can I "connect" them ? (in order to allow the user to click on any segment and antire path to be selected)
Thank you,
Best  Regards,
Adrian
    Adrian,
    I'm not quite sure why this happens - please contact customer support and we can investigate (if you've not done so already).
