  3. How to get back to tcl after exiting in OCEAN and/or SKILL...
  • Replies 12
  • Views 7742
How to get back to tcl after exiting in OCEAN and/or SKILL?
Reinice
Reinice over 13 years ago
Hi All,
Good Day.
I 'am running tcl in compiling/creating OCEAN and/or SKILL files. When I exit in OCEAN and/or SKILL I can't get back to tcl to compile the remaining tcl codes. Is there a way to get back to tcl after exiting in OCEAN and/or SKILL?
Thank you very much in advance.
Reinice
  • Reinice
    I tried your suggestion adding "global finished" within the main proc. It did not exit in ocean. I checked the processes running with "ps" and it is still running.
    I made some workaround that worked. Here's my script:
    proc main {design_user tool_u analysis_name} {
    proc showOutput {channel} {
      global finished
      gets $channel line
      set finished [string match "*Finished*" $line]
      puts $finished
      if {$finished == 1} {
        close $channel
      } else {
        puts $line
    set finished 0
    set my_IO [open "| ocean -restore myScript.ocn"]
    fconfigure $my_IO -buffering line
    fileevent $my_IO readable [list showOutput $my_IO]
    puts $finished
    vwait finished
    puts "NOTE: simulation has now finished"
    main $design_user $tool_u $analysis_name
    In myScript.ocn there's a line at the end of the file that shows it "Finished" it's execution. This workaround exits in ocean session and returned in main procedure.
    Thanks and Regards,
    Reinice
    I can't explain why it is not exiting for you, but at least you have a workaround.
