  3. how to create an arbitrary size matrix with the elements...
  • Views 14485
how to create an arbitrary size matrix with the elements alonging with specific distribution?
imagesensor123
imagesensor123 over 13 years ago
       I would like to create a matrix size, such as 100x100, all these 10000 elements in the matrix is in normal distribution. how can I set up the matrix? how can I arrange these elements in random position in the matrix.
      for example: I have 10 elements equal to "20"
                                   5 elements equal to "100"
      I'd like these ten elements "20" to be set randomly in the matrix 100x100.
welcome to any discussion
regards,
zfeng
    Zfeng,
    Something like this:
    procedure(CCFbuildMatrix(N mean sigma)
      let((matrix column)
        matrix=makeVector(N)
        for(x 0 N-1
          matrix[x]=column=makeVector(N)
          for(y 0 N-1
            ; convert to integer, clip, do whatever you want here.
            ; in this case I just stretched the normal distribution to the
            ; desired mean and standard deviation
            column[y]=abRandomNormal()*sigma+mean
      matrix
    This uses the code below to generate random numbers with a gaussian distribution. The return value of this is a matrix - so you can do:
    > m=CCFbuildMatrix(100 50 10)
    array@0x90ac678
    > m[2][4]
    53.99555
    > m[6][8]
    47.73704
    For example.
    /* abRandomNormal.il
    Author     A.D.Beckett
    Language   SKILL
    Date
    Modified
    By
    Uses Box-Muller method to produce random numbers with
    a normal distribution (mean 0, std dev 1).
    Call abRandomNormal() multiple times to get such a sequence.
    SCCS Info: @(#) abRandomNormal.il 11/30/12.14:22:28 1.1
    ; Store math constants (such as PI) as properties on this symbol
    (defMathConstants 'abRandomNormal)
    *                       (abRandomNormal)                       *
    *  Return a random number with normal distribution using the   *
    *                      Box-Muller method                       *
    (defun abRandomNormal ()
      (let ((max (rightshift -1 1)) U V)
        (setq U (quotient (float (random max)) max))
        (setq V (quotient (float (random max)) max))
        ; could generate two independent numbers
        ; the other would use cos instead of sin
        (times (sqrt (times -2 (log U)))
               (cos (times 2 (getqq abRandomNormal PI) V)))
    *             (abTestRandomNormal numPoints bins)              *
    *   Function for testing - uses ViVA's plotting functions to   *
    *  produce a histogram and also compute the mean and std dev   *
    *      to ensure that with enough points it looks normal       *
    *               (e.g numPoints 100000, bins 100)               *
    (defun abTestRandomNormal (numPoints bins)
      (let (x y wave)
        (setq x (drCreateVec 'intlong numPoints))
        (setq y (drCreateVec 'double numPoints))
        (for i 0 numPoints
             (drAddElem x i)
             (drAddElem y (abRandomNormal))
        (setq wave (drCreateWaveform x y))
        (awvPlotWaveform (newWindow) (list (histo wave bins nil nil)))
        (printf "Mean=%g\nStd Dev=%g\n" (average wave) (stddev wave))
