  3. leHiCreateGroup
  • Views 13804
leHiCreateGroup
howardhaoracle
howardhaoracle over 13 years ago
 Hi..
I am trying to group a selected group of metal into 1 group. But everytime I do leHiCreateGroup, there is a GUI window popup "Create Group" and you have to hit apply in order to create group.. It's kinda annoying to hit apply everytime.. Is there any other Skill command I can use to bypass this popup GUI window and achieve the same result..
Thank you very much for your help
Howard
  • skillUser
    skillUser over 13 years ago
    Hi Howard,
    I have not looked into this in detail but I think that you will want to look at the lower level db* commands such as dbCreateFigGroup and dbAddFigToFigGroup - this is essentially what the other command is doing: creating a fig group and putting the selected figures in that group.  Create a procedure that creates a fig group and then adds each of the selected figures to that fig group in turn.
    Any time you see a "Hi" in the name of a command, or "hi" as the prefix, this is short for "human interface" and typically would involve some interaction with the user through a form, menu, bindkey etc.  In this case the function has a "le" prefix which indicates it is for the layout editor tool and then the Hi part of the name suggests that it will invoke or need a form to gather further input from the user.
    Hopefully this information helps.
    Lawrence.
  • howardhaoracle
    Thanks Lawrence..
    After using both command dbCreateFigGroup and dbAddFigToGroup, I am able to create group w/o that GUI popup window
    Howard
