  3. creating list of celviews
  • Views 14743
sanramz
sanramz over 12 years ago
   I am trying to create multiple new layouts from a list unix file in to one library. In each cell Iam also trying to create a PR boundary with the coordinates that are present in the unix file.
The list file contains the cell name and PR boundary coordinates as shown below.
cell_name                       llx    lly    urx       ury
BUF                                0     0     4.448    4.424
AND                                0     0     4.448    4.424
 My code for this is as shown below.
ListPath = "/home/san/tiler/cell_list"
;lib_name="test"
inPort = infile( ListPath )
when( inPort
while( gets( line inPort )
;println( nextLine )
lineData = parseString(line " ")
        ;portTable[car(lineData)] = evalstring(cadr(lineData))
;cell_name=car(lineData)
cell_name=nth(0 lineData)
llx=nth(1 lineData)
lly=nth(2 lineData)
urx=nth(3 lineData)
ury=nth(4 lineData)
create_boundary(cell_name llx lly urx ury)
close( inPort )
procedure(create_boundary(cell_name llx lly urx ury)
let (cv)
cv=dbOpenCellViewByType("test" "cell_name" "layout" "maskLayout" "w")
dbCreateRect(cv list("prBoundary" "drawing") list(llx:lly urx:ury))
dbSave(cv)
);procedure
For this code, I am getting the following error.
*Error* eval: undefined function - create_boundary
*Error* load: error while loading file - "create_cell.il" at line 20
  Kindly help me to solve this.
Is it because of the "parsing", as i expect \n is coming for the "urx" variable when I try to access it??
santhosh.
  • sanramz
    BUF                                0     0     4.448    4.424
    AND                                0     0     4.448    4.424
    ;lib_name="test"
    when( inPort
    llx=nth(1 lineData)
    lly=nth(2 lineData)
    urx=nth(3 lineData)
    ury=nth(4 lineData)
    close( inPort )
    let (cv)
    dbSave(cv)
    );procedure
    santhosh.
    Two problems (at least, may be more because I didn't try the code)
    1. The function create_boundary is not defined until after it's called, which is why you have the problem you're seeing. If the main bit of the code had been contained within a function definition, that would have been OK, because loading the file would have defined the functions rather than executing them. In other words, if you'd put procedure(createBoundaryFromFile(ListPath)... around your main code, the forward reference would have been fine because you would not have been calling create_boundary before it had been defined. Then after loading the code, you'd do createBoundaryFromFile("/path/to/the/file")
    2. The coordinates will all be strings, so you should do atof(nth(1 lineData)) etc.
    Note too that if this is for IC61, you'd have to use dbCreatePRBoundary rather than creating a shape on the PRBoundary/drawing LPP.
    I saw (now that I'm on the network) that you'd both posted this as a separate question, and as an append to an old thread. So I've split off your append to the old thread (together with my reply above) and merged it with your standalone question.
    The forum guidelines advise against double posting and also against appending old threads.
