  3. Unable to open nodeset file Warning
  • Views 14631
Eshar
Eshar over 12 years ago
I have noticed that in my SP simulations the following warning occurs when a DC operating point simulation doesn't precede it:
WARNING (CMI-2015): Unable to open nodeset file `spectre.dc'. No such file or directory.
 Could someone please clarify what the function of the spectre.dc file in performing a SP simulation? Also, why is this a warning instead of an error?
Thanks for the help.
    Most likely you have the readns parameter on one of the analyses (for example the sp analysis) set to "spectre.dc". This tells whichever analysis it is to try to read the nodeset file as a hint for the DC algorithm that precedes the analysis (pretty much every analysis requires a DC operating point to start from, including an S-parameter analysis). If the file is missing, it will solve the DC operating point as usual - the file is just a hint.
    The reason why it's not an error is that quite often you do things like this:
    dc dc readns="spectre.dc" write="spectre.dc"
    Which means the first time it will give you a warning, then write the DC operating point at the end of the simulation. The second run, the file will exist, and it will use that as a starting point. We try to make it not too critical if the file doesn't exist - since it is a hint.
    If you really want it to error out, you can do that by adding this option into your netlist:
    increaseSeverity options warning_change_severity=error warning_id=[CMI-2015]
    And then it will fail:
     Error found by spectre during DC solution estimation, during DC analysis `dc'.
        ERROR (CMI-2015): Unable to open nodeset file `spectre.dc'.
  • Eshar
    Makes sense. Thanks.
